  • Bijesh Tank 192 posts 420 karma points
    Jun 26, 2013 @ 11:57
    Bijesh Tank
    How add a language in the backend?
    HI,
    I have a multi-lingiual site that uses dictionary items. There is a need from the client to setup a new site in English (Bangladesh), however this does not exist in the list of available languages. I understand the languages list is the offical list from MSDN (http://msdn.microsoft.com/en-gb/goglobal/bb896001.aspx) but is there anyway to add more languages to the list?
    Or is there another way I can get around this? Any advise would be greatly appreciated.
    Bij
    Jun 26, 2013 @ 12:37
    Jeroen Breuer
    It might be a good idea to have a look at the source to see where the languages are fetched from. If it's a hard coded list you could add it in the source code and maybe create a pull request for it: https://github.com/umbraco/Umbraco-CMS
    Jeroen
    Jun 26, 2013 @ 13:18
    Bijesh Tank
    Thanks Jereon. I've got the source but it's been a little while since I looked at it - have you got any pointers where I can start looking?
    Jun 26, 2013 @ 13:21
    Jeroen Breuer
    There is a /umbraco/settings/editLanguage.aspx file so I think that's a good start :-).
    Jeroen
    Jun 26, 2013 @ 13:29
    Bijesh Tank
    Excellents thanks!
  • Allan Kirk 36 posts 110 karma points c-trib
    Dec 04, 2013 @ 04:09
    Allan Kirk
    Did you find a solution to this problem? I might need to add Burmese to the list, and would prefere not to have to start from scratch, so if you could give me some pointers, that would be much appreciated.
    Thanks.
