    Sep 21, 2009 @ 22:12
    Rich Green
    Limiting content to a certain number of levels?
    If I have a site structured like this, all document types are the same
    Home
    - Nav 1
    - Nav 2
    - Sub Nav 1
    - Sub Nav 2
    - Nav 3
    - Sub Nav 1
    - Sub Sub Nav 1
    Is there anyway of stopping a user creating
    - Sub Sub Sub Nav  and then
    - Sub Sub Sub Sub Nav'
    etc. etc.
    Cheers
    Rich
    Sep 21, 2009 @ 22:36
    Dirk De Grave
    Hi Rich,
    unfortunately not, unless you're coding an event handler that listens for new events on document, and cancel the event when level of new document exceeds a predefined level.
    Lots of info on event handlers and their implementation can be found on the wiki.
    Hope this helps.
    Regards,
    /Dirk
    Sep 21, 2009 @ 22:38
    Rich Green
    Thanks Dirk, that makes sense.
  • Søren Linaa 255 posts 208 karma points
    Sep 21, 2009 @ 22:52
    Søren Linaa
    Well a simplier approach could be to make a documenttype for each level.
    In V4 you can make a master documenttype with all the properties and then make child documenttypes for each level that inherit from the master
    This way you can control the types of documenttypes you want the user to create and the number of levels.
    / cheers
    Søren
    Sep 21, 2009 @ 22:58
    Rich Green
    Thanks Søren, I'll have a look at master/child doc types, sounds like that could work.
    Rich
