Cannot get Umbraco navigation XSLT for pages in sub folder to work
I know this should be simple but I really am useless with XSLT (I'm learning though...).
I am building my first Umbraco site and have the dynamic navigation working for the top menu but I am failing on the footer menu (nothing is showing).
The site structure is:
Site (Master template - level 1) - Home (content page) - Candidates (content page) - Contact (content page) - Clients (content page) - Footer Pages (Container folder hidden from Nav - level 2) - Links - Terms and Conditions - Cookies - Privacy Policy
I would have thought I could use more or less the same XSLT as the top menu (shown below) but use level 2 rather than level 1 but this is not working (nothing is pulled out):
So I'm just trying to list out the footer pages of (Links | Terms & Conditions | Cookies | Privacy Policy)...
Any guidence would be fantastic. Thanks!
Here is the site XML:
<!DOCTYPE root[ <!ELEMENT umbBlog ANY> <!ATTLIST umbBlog id ID #REQUIRED> <!ELEMENT umbBlogPost ANY> <!ATTLIST umbBlogPost id ID #REQUIRED> <!ELEMENT ContentFolder ANY> <!ATTLIST ContentFolder id ID #REQUIRED> <!ELEMENT DateFolder ANY> <!ATTLIST DateFolder id ID #REQUIRED> <!ELEMENT umbHomepage ANY> <!ATTLIST umbHomepage id ID #REQUIRED> <!ELEMENT umbNewsArea ANY> <!ATTLIST umbNewsArea id ID #REQUIRED> <!ELEMENT umbNewsArticle ANY> <!ATTLIST umbNewsArticle id ID #REQUIRED> <!ELEMENT Team24HomePage ANY> <!ATTLIST Team24HomePage id ID #REQUIRED> <!ELEMENT Team24InnerPage ANY> <!ATTLIST Team24InnerPage id ID #REQUIRED> <!ELEMENT Team24MasterPage ANY> <!ATTLIST Team24MasterPage id ID #REQUIRED> <!ELEMENT umbTextpage ANY> <!ATTLIST umbTextpage id ID #REQUIRED> <!ELEMENT umediaSlider ANY> <!ATTLIST umediaSlider id ID #REQUIRED> <!ELEMENT umediaSliders ANY> <!ATTLIST umediaSliders id ID #REQUIRED> ]>
- Links
- Cookies
- Privacy Policy
<!DOCTYPE xsl:stylesheet [
<!ENTITY nbsp " ">
<xsl:stylesheet
version="1.0"
<xsl:variable name="level" select="1"/>
<xsl:template match="/">
<ul id="topNavigation">
<xsl:for-each select="$currentPage/ancestor-or-self::* [@level=$level]/* [@isDoc and string(umbracoNaviHide) != '1']">
<li>
<xsl:if test="@id = $currentPage/@id">
<xsl:attribute name="class">active</xsl:attribute>
</xsl:if>
<a class="navigation" href="{umbraco.library:NiceUrl(@id)}">
<span><xsl:value-of select="@nodeName"/></span>
</a>
</li>
</xsl:for-each>
</ul>
</xsl:template>
</xsl:stylesheet>
<!DOCTYPE root[
<root id="-1">
<Team24MasterPage id="1120" parentID="-1" level="1" creatorID="0" sortOrder="3" createDate="2013-06-26T11:06:54" updateDate="2013-06-26T11:21:36" nodeName="Team 24 Site" urlName="team-24-site" path="-1,1120" isDoc="" nodeType="1119" creatorName="admin" writerName="admin" writerID="0" template="0">
<Team24HomePage id="1096" parentID="1120" level="2" creatorID="0" sortOrder="0" createDate="2013-06-20T00:33:15" updateDate="2013-06-26T11:28:37" nodeName="Home" urlName="home" path="-1,1120,1096" isDoc="" nodeType="1092" creatorName="admin" writerName="admin" writerID="0" template="1093">
<homepagePageTitle>Team 24 Home Page</homepagePageTitle>
<homepageMetaDescription>Description of the page goes here</homepageMetaDescription>
<homepageMetaKeywords>keywords,go,here</homepageMetaKeywords>
<homepageHeading1>Homepage Header Goes Here</homepageHeading1>
</Team24HomePage>
<Team24InnerPage id="1103" parentID="1120" level="2" creatorID="0" sortOrder="1" createDate="2013-06-21T01:46:07" updateDate="2013-06-26T12:25:51" nodeName="Candidates" urlName="candidates" path="-1,1120,1103" isDoc="" nodeType="1094" creatorName="admin" writerName="admin" writerID="0" template="1095">
<pageTitle>Candidates</pageTitle>
<metaDescription>Meta Description Goes Here</metaDescription>
<metaKeywords>keywords,go,here</metaKeywords>
<innerPageHeading1>Candidates</innerPageHeading1>
<innerPageHeading2 />
</Team24InnerPage>
<Team24InnerPage id="1105" parentID="1120" level="2" creatorID="0" sortOrder="2" createDate="2013-06-21T01:47:44" updateDate="2013-06-26T11:25:04" nodeName="Contact" urlName="contact" path="-1,1120,1105" isDoc="" nodeType="1094" creatorName="admin" writerName="admin" writerID="0" template="1095">
<pageTitle>Contact</pageTitle>
<innerPageHeading1>Contact</innerPageHeading1>
</Team24InnerPage>
<Team24InnerPage id="1102" parentID="1120" level="2" creatorID="0" sortOrder="3" createDate="2013-06-21T00:58:03" updateDate="2013-06-26T11:25:04" nodeName="Clients" urlName="clients" path="-1,1120,1102" isDoc="" nodeType="1094" creatorName="admin" writerName="admin" writerID="0" template="1095">
<pageTitle>Clients</pageTitle>
<innerPageHeading1>Clients</innerPageHeading1>
</Team24InnerPage>
<ContentFolder id="1112" parentID="1120" level="2" creatorID="0" sortOrder="4" createDate="2013-06-26T09:53:08" updateDate="2013-06-26T11:25:04" nodeName="Footer Pages" urlName="footer-pages" path="-1,1120,1112" isDoc="" nodeType="1111" creatorName="admin" writerName="admin" writerID="0" template="0">
<Team24InnerPage id="1116" parentID="1112" level="3" creatorID="0" sortOrder="12" createDate="2013-06-26T09:54:25" updateDate="2013-06-26T11:21:37" nodeName="Links" urlName="links" path="-1,1120,1112,1116" isDoc="" nodeType="1094" creatorName="admin" writerName="admin" writerID="0" template="1095">
<pageTitle>Links</pageTitle>
<innerPageHeading1>Links</innerPageHeading1>
</Team24InnerPage>
<Team24InnerPage id="1115" parentID="1112" level="3" creatorID="0" sortOrder="13" createDate="2013-06-26T09:54:11" updateDate="2013-06-26T11:21:37" nodeName="Terms &amp; Conditions" urlName="terms-amp-conditions" path="-1,1120,1112,1115" isDoc="" nodeType="1094" creatorName="admin" writerName="admin" writerID="0" template="1095">
<pageTitle>Terms and Conditions</pageTitle>
<innerPageHeading1>Terms and Conditions</innerPageHeading1>
</Team24InnerPage>
<Team24InnerPage id="1114" parentID="1112" level="3" creatorID="0" sortOrder="14" createDate="2013-06-26T09:53:54" updateDate="2013-06-26T11:21:37" nodeName="Cookies" urlName="cookies" path="-1,1120,1112,1114" isDoc="" nodeType="1094" creatorName="admin" writerName="admin" writerID="0" template="1095">
<pageTitle>Cookies</pageTitle>
<innerPageHeading1>Cookies</innerPageHeading1>
</Team24InnerPage>
<Team24InnerPage id="1113" parentID="1112" level="3" creatorID="0" sortOrder="15" createDate="2013-06-26T09:53:44" updateDate="2013-06-26T11:21:37" nodeName="Privacy Policy" urlName="privacy-policy" path="-1,1120,1112,1113" isDoc="" nodeType="1094" creatorName="admin" writerName="admin" writerID="0" template="1095">
<pageTitle>Privacy Policy</pageTitle>
<innerPageHeading1>Privacy Policy</innerPageHeading1>
</Team24InnerPage>
<umbracoRedirect />
<umbracoNaviHide>1</umbracoNaviHide>
</ContentFolder>
<footerLinkedinLink>http://www.linkedin.com/profile/view?id=8209529&locale=en_US&trk=tyah</footerLinkedinLink>;
<headerTelephoneNumber>0845 370 2424</headerTelephoneNumber>
</Team24MasterPage>
</root>
