I just stumbled across a problem with the recycle bin. If your users don't have access to the root "Content" node, they can't see the recycle bin. In my case, most of my users have a starting node somewhere below "Content" so they can't use the functionality of the recycle bin.
I just viewed some of the new videos on custom sections and trees, and I'm curious if a custom section for the recycle bin might be possible. I've gone through the steps of creating a custom section, so that's no problem, but I'm not sure how I would add the "recycle bin" tree to my new section. This would allow me to grant permissions on the recycle bin without requiring me to make a bunch of changes to the way Im already managing permissions in the content section. Besides, I have no interest in managing permissions on a node-by-node basis, I'd rather just assign a starting node to a user and call it good.
The recycle bin is global to umbraco and does not follow the user access rules. So providing access to the recycle bin would give access to content you have normally hidden from users.
That aside, to accomplish what you want regarding a custom section you will need to do some coding. Basically build a custom section (which you've done) and build a custom tree for that section which reads the node structure under the Recycle Bin node from the database and display it as a tree. Node -20 in my installation.
You then need create your own "MOVE" function on the right click event for those nodes in order to restore the nodes.
I don't believe their is a "SHOW RECYCLE BIN" function for the custom section. The good news with custom sections is you can do a lot...bad news is you have to do a lot :)
Download the sample project for custom sections from Tim Geyssens blog for a framework to get you started:
I don't think the recycle bin should go into a new section, I'd rather create a work item on Codeplex asking to include the recycle, regardless of user settings (Of course, recycle bin should be filtered for only items you're allowed to see/restore/delete. +1 if you create the work item.
Ditto this as a "basic" feature request; users should be able to undelete their own postings, even if they are restricted to certain node trees. I'm not much of a programmer, but just make Recycle Bin available to all users, and only display deleted items authored by the logged-in user?
Same goes for the "Last Edits" tab (for users that don't have access to the root Content node): it appears when a user first logs on, but then once they click any node, it goes away. Not obvious that you have to hit Refresh to redisplay the initial page to get Last Edits tab to reappear.
Recycle Bin as Custom Section
Thoughts?
http://www.nibble.be/wlwimages/Addinganewcustomsectiontoumbracodemoproj_D4AE/CustomUmbracoSection.zip
-Chris
Anyone ever had any luck with this, otherwise I might look at it but don't want to re-invent the wheel.
Rich
/Dirk
Agreed 100% as my post with link to Codeplex work item here
http://our.umbraco.org/forum/using/ui-questions/2052-User-can't-access-recycle-bin-when-assigned-to-a-level-1-start-node
Find it strange that it does not affect more people?
Rich
This is as of Umbraco 6.1.1. build 4 (June 2013).
