  • Vanja Tesin 30 posts 55 karma points
    Sep 22, 2009 @ 13:23
    Vanja Tesin
    How to creata a package that has upgrade option
    I've successfully created a package to distribute our site but I was wondering how to create a package to that I can easily update it once I make changes to the original version.
    Can that be done from package manager in Umbraco 4, or do I have to add something in package.xml?
    Sep 25, 2009 @ 17:49
    Vanja Tesin
    To rephrase my question: how does umbraco detects if a package has a newer version than installed?
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    Sep 25, 2009 @ 22:29
    Richard Soeteman
    Hi Vanja,
    There is no build in support for that so you have to create upgrade packages for that.
    Richard
    Sep 30, 2009 @ 15:34
    Vanja Tesin
    Hi Richard,
    Thanks!
  • Connie DeCinko 931 posts 1160 karma points
    Dec 17, 2010 @ 17:56
    Connie DeCinko
    Richard,
    How do you create upgrade packages?  I installed a package a second time and instead of upgrading/overwriting the previous package, it created a duplicate in my list of installed packages.
