  • Garrett Fisher 341 posts 496 karma points
    Sep 22, 2009 @ 15:18
    Garrett Fisher
    Basic Umbraco Deployment Question
    I need to copy an am Umbraco site from my local instance to a staging environment but obviously do not want to re-create the entire site in the CMS on the new server.  Can anyone tell me what the relevant folders are that need to be copied to the new instance (in addition to a database restore)?  I am having a hard time identifying exactly what I am editing when I am using the CMS UI.
    Garrett
    Sep 22, 2009 @ 15:40
    Dirk De Grave
    Garrett,
    Here's another thread that discusses similar situation: http://our.umbraco.org/forum/getting-started/installing-umbraco/3936-How-to-duplicate-an-Umbraco-installation
    In short: backup local db, restore on staging server, copy all local files to remote staging environment, change web.config to point to new db and launch new site. If site doesn't show up immed, perform a 'Publish entire site' from right click on 'Content' node in content section.
    /Dirk
  • Richard Soeteman 4051 posts 12924 karma points MVP 2x
    Sep 22, 2009 @ 15:41
    Richard Soeteman
    Hi Garret,
    If the Version of Umbraco on your local machine and your staging env are the same, I would say copy the folders :
    - Css
    - MasterPages
    - Media
    - Scripts
    - XSLT
    If you are using Usercontrols also copy the usercontrols folder and the bin folder for your local dll
    Then restore the database and make sure you republish the entire site by richt clicking on content -> Republish entire site in Umbraco.
    Hope this helps,
    Richard
    Sep 22, 2009 @ 15:45
    Garrett Fisher
    Hi Richard--
    Thanks so much for your speedy reply.  This is my first Umbraco site, so please forgive me if my questions are silly.  How do I know if I'm using Usercontrols?
    Thanks again,
    Garrett
  • bhunt 18 posts 22 karma points
    Sep 22, 2009 @ 23:28
    bhunt
    Garrett-
    Usercontrols are found inside a usercontrols folder in the root of the site. Some packages make use of usercontrols. For example - if you use the runway starter site, it makes use of a usercontrol for a contact form. That particular one usually shows up inside a folder called runway that is inside the usercontrols folder.
    Sometimes if you write custom code, you would put that in a usercontrol and then create a macro that uses that control.
    So perhaps if you see anything inside your /usercontrols folder, you can move that as well.
    Sep 23, 2009 @ 00:55
    Rich Green
    Garrett,
    Unless you have a good reason not too you can just copy all the folders up to the staging environment.
    As mentioned the web.config file needs to be unique to your staging server (the database connection string will more than likely be different)
    Rich
    Sep 23, 2009 @ 21:01
    Richard Soeteman
    Hi Garret,
    Just check if the usercontrol folder locally is empty, if so you are not using Usercontrols :) It's indeed also possible to copy all the folders. Just some extra time for the upload
    Richard
    Oct 05, 2009 @ 19:10
    Garrett Fisher
    Guys,
    I sent the entire package to the client's techm, along with a BAK file from which he can restore the database.  He was able to successfully install Umbraco, and he restorede the database from my backup.  However, he is unable to log in using the same credentials that I use for my local instance (I verified that they work).
    Is this expected behavior?  Is there anything else we need to do?  Does anyone see any issues with this process?
    Thanks and help!
    //Garrett
    Oct 05, 2009 @ 21:18
    Dirk De Grave
    Are you sure web.config both are the same (maybe not for the db connection string), but make sure membership's password format is identical on both systems.
    Hope this helps.
    Regards,
    /Dirk
  • Sawe 2 posts 22 karma points
    May 22, 2013 @ 13:04
    Sawe
    Dirk you are right, the database user needs to have db_datareader, db_datawriter/,db_owner role membership in sql server, i.e. right click on the user, go to Membership, and give the user enough rights to read and write to the database. one way of checking if the user has rights, login to the database via Sql Server Management Studio using the user's credentials. If you can see the tables and data, then u are good to go.
    Regards,
    Sawe
