  • Mark 4 posts 24 karma points
    Jul 06, 2013 @ 16:25
    Mark
    Acces Usercontrol property id within the usercontrol
    Hi guys, i would like to retrieve the property.Id of the current usercontrol within itself.. I am trying to build a photo gallery which one could attach to a mediafolder. Then on save i would like to auto generate thumbnails with a path something like '/documentId/uc_propertyId/mediaId.ext'.. Doing so without hardcoding any ids or aliases, because of situations in which there are two galleries on the same document.
    Thnx in advance!
    protected void Page_Load(object sender, EventArgs e)
        _currentNodeId = int.Parse(Request.QueryString["id"]);
        Document d = new Document(_currentNodeId);
        foreach (Property p in d.GenericProperties)
    Jul 08, 2013 @ 12:16
    Jeroen Breuer
    I know with DAMP I use some code to get the propertyId. Maybe that can help: http://damp.codeplex.com/SourceControl/latest#DigibizAdvanceMediaPicker/DAMP_DataType.cs
    Jeroen
    Jul 09, 2013 @ 18:56
    Mark
    Hey Jeroen,
    Thnx for your response! I ended up adding an extra textbox (only visible to admins) to the usercontrol, so the developer can now define a subfolder for each instance of the PhotoGallery. Thnx for all the help anyway.
    Greetings,
    Mark
