I've tried the above and I still not getting a title attribute in my img tags.
My tinyMceConfig.config allows title as a valid element.
If I add one in manually once I've inserted an image via the source editor then is remains there when it is published and viewed. I think it is being ommitted or stripped out by one of the following
tinymce (or umbraco) strips title attribute of img tags
If I insert an image with the richtext editor and save/publish the node, somehow the title attribute inside the img-tag gets deleted.
I already set the TidyEditorContent to "False" in config\umbracoSettings.config
It's strange... because a fresh installed umbraco also deletes those img title attributes. But title attributes in <a>-tags are working :O
I just browsed the umbraco config for valid elements for TinyMCE and found this:
Note the equal sign before the title attribute. But this seems to be correct. http://wiki.moxiecode.com/index.php/TinyMCE:Configuration/valid_elements#Default_rule_set:
Any ideas?
Sandro,
I have had similar problems to this. I had to add 'rel=0'?
The full forum discussion: http://forum.umbraco.org/yaf_postst4580_TinyMCE-stripping-out-img-id-attributes.aspx
In order to get the title tag to show,
1) Open umbracoSettings.config in the config folder
2) Towards the top, you should see <allowedAttributes> under <imaging>
3) Change
to
4) Touch the web.config or recycle the application pool to restart Umbraco
Enjoy!
Donald
That fix worked on our installation of Umbraco. Thanks!
This is happening with Umbraco 5. Is there a new method to fix this issue?
Thanks Donald. This fix also worked for me.
Hi guys,
Any help would be greatly appreciated :-)
