  • Sean Parsons 23 posts 38 karma points
    Sep 27, 2009 @ 17:27
    Sean Parsons
    Decimal Validation in Doc Type Properties
    Hi all,
    I need to add validation for basic decimal entry (eg. a price field)
    The regular expression I am trying to use is:
    ^(\d+((\.\d{1,2}){1})?)$
    This is valid (tested with The Regulator tool, if anyone knows that one) but anything other than an integer gets rejected by Umbraco validation with that expression. (I've tried it with and without the ^ and $)
    Sean
  • Masood Afzal 176 posts 522 karma points
    Sep 27, 2009 @ 17:31
    Masood Afzal
    Integer:   [0-9]*
    Double:   [0-9][\.0-9]*
    Sep 27, 2009 @ 21:32
    Sean Parsons
    Thanks - simpler... However, any idea why the original (and also valid) regex doesn't work in Umbraco?
    I'd like to find out why, in case I have a need for more complex regexes and I come up against this again...
    Sep 27, 2009 @ 21:35
    Sean Parsons
    Oh - and how would you limit it to 2 decimal places?
  • Richard Soeteman 4053 posts 12926 karma points MVP 2x
    Sep 28, 2009 @ 06:11
    Richard Soeteman
    HI Sean,
    If you use a Regular expression it comes from regxeplib.com. The site has a nice tester so you could use  the regular expression of choise that you find there and tweak it for your own needs.
    Richard
    Sep 28, 2009 @ 22:15
    Sean Parsons
    I have tried that regex tester on that site for ^(\d+(\.\d{1,2})?)$ and it gives me the results I expect.
    However, I still cannot get this to work in Umbraco. Any other ideas out there?
    I'm a bit concerned, as this isn't a particularly complex regex - but Umbraco blanks out the value and raises a validation error.
    Perhaps some characters need to be escaped?
    Sep 30, 2009 @ 11:01
    Richard Soeteman
    Hi Sean,
    I assume that teh underlying datatype is a string instead of number?
    Richard
  • Petr Snobelt 923 posts 1535 karma points
    Sep 30, 2009 @ 12:58
    Petr Snobelt
    @richard: It must be string, numeric datatype dosn't allow decimal separator
    Sep 30, 2009 @ 22:05
    Sean Parsons
    Man oh man. It's always the simplest of things, isn't it?? Thanks Richard and Petr.
