  • Julius Bartkus 51 posts 76 karma points
    Sep 28, 2009 @ 02:59
    Julius Bartkus
    dictionary item into asp:login control
    Hello all,
    In the template I was trying to insert a Dictionary item but with no luck:
    <asp:Login
                ID="Login1"
                runat="server"
                LoginButtonText="<umbraco:Item field='#loginButton' runat='server'></umbraco:Item>">
    </asp:Login>
    Any suggestions how could it be solved?
    Thanks.
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Sep 28, 2009 @ 06:17
    Richard Soeteman
    What I usually do is creating a usercontrol the I place the logincontrol onto that usercontrol and use the usercontrol as a Macro. Then you can change the loginbutton text by.
    protected void Page_Load(object sender, EventArgs e)
    Login1.LoginButtonText.Text = umbraco.
    library.GetDictionaryItem("loginButton");
    Hope it helps you,
    Richard
    Sep 28, 2009 @ 08:59
    Dirk De Grave
    2
    Or if you don't want the hassle of creating the user control as Richard is suggesting, you could write this piece of code into the template that contains the login control
    <script runat="server">
    protected void Page_Load(object sender, EventArgs e) {
       Login1.LoginButtonText.Text = umbraco.library.GetDictionaryItem("loginButton");
    </script>
    /Dirk
    Sep 28, 2009 @ 14:46
    Julius Bartkus
    Thanks!:)
