  • Jeffrey Schoemaker 408 posts 2138 karma points MVP 8x c-trib
    Jul 22, 2013 @ 17:21
    Jeffrey Schoemaker
    Editing a document type gives Aborted
    Hi all,
    I have a site running and "suddenly" one document type can't be edited anymore. I was working on 4.7.1.1, and I hoped an upgrade to 6.1.2 would fix this, but it didn't.
    When the URL (/umbraco/settings/editNodeTypeNew.aspx?id=1965) is executed it gives "Aborted" and the following message in Firefox: The connection has been reset ("De verbinding werd geherinitialiseerd").
    There are no weird datatypes or such on the documenttype and all other doc.types are working fine. I also looked into the database (table [cmsPropertyType]) and everything looks fine. I've never seen this before in other Umbraco installations and Google-ing doesn't help either. There's nothing in the UmbracoLog-table or in my Event Viewer.
    Does anyone has any clue?
    Great thanks in advance,
    Jeffrey
    Jul 23, 2013 @ 09:50
    Dave Woestenborghs
    Do you have some eventhandler that can cause this problem ? Do you have any custom packages installed ?
    Jul 23, 2013 @ 09:52
    Dave Woestenborghs
    (double post)
    Jul 23, 2013 @ 11:01
    Jeffrey Schoemaker
    I don't have any eventhandlers. I have some custom packages installed: EmbeddedContent, Document Type Fieldsets and uComponents.
    The node in the content tree is still working perfectly, only the editing of the documenttype doesn't work.
    Hope anybody could help me,
    Jeffrey
    Jul 23, 2013 @ 11:08
    Dave Woestenborghs
    What kind of datatypes are you using on the doctype ? Do you have some errors in your logfiles ?
    Jul 23, 2013 @ 12:04
    Jeffrey Schoemaker
    There are only textstrings, textboxmultiples and RTE's on it.
    There is nothing in the logfiles.
    Jul 23, 2013 @ 12:15
    Dave Woestenborghs
    May sound stupid. But check your validation settings on the properties. I had this once when I added just plain text in the regex box.
    Jul 23, 2013 @ 12:20
    Jeffrey Schoemaker
    I can't see the validation on the properties, because the problem is that the page isn't rendered when trying to edit the doc.type. And I know that there isn't any validation on my properties, because I never do that.
    Jul 23, 2013 @ 12:23
    Jeffrey Schoemaker
    Ah, I finally got the error while recreating the doc.type
    Event code: 3005
    Event message: An unhandled exception has occurred.
    Event time: 23/07/2013 12:21:15
    Event time (UTC): 23/07/2013 10:21:15
    Event ID: 0061cbbb7ca8421db6a1656f61b2ddac
    Event sequence: 1467
    Event occurrence: 4
    Event detail code: 0
    Application information:
        Application domain: /LM/W3SVC/73/ROOT-2-130190470171727808
        Trust level: Full
        Application Virtual Path: /
        Application Path: D:\Projecten\...\UmbracoCms.6.1.2\
        Machine name: DEVELOP
    Process information:
        Process ID: 11060
        Process name: w3wp.exe
        Account name: IIS APPPOOL\WPD
    Exception information:
        Exception type: HttpException
        Exception message: Exception of type 'System.Web.HttpException' was thrown.
       at System.Web.UI.Page.ExecuteRegisteredAsyncTasks()
       at umbraco.controls.ContentTypeControlNew.save_click(Object sender, ImageClickEventArgs e)
       at System.Web.UI.WebControls.ImageButton.OnClick(ImageClickEventArgs e)
       at System.Web.UI.WebControls.ImageButton.RaisePostBackEvent(String eventArgument)
       at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
    Input string was not in a correct format.
    Server stack trace:
       at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
       at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
       at umbraco.controls.GenericProperties.GenericProperty.get_Type()
       at umbraco.controls.ContentTypeControlNew.UpdatePropertyTypes(IContentTypeComposition contentTypeItem)
       at umbraco.controls.ContentTypeControlNew.<save_click>b__4(SaveAsyncState asyncState)
       at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs)
       at System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage(IMessage msg, IMessageSink replySink)
    Exception rethrown at [0]:
       at System.Runtime.Remoting.Proxies.RealProxy.EndInvokeHelper(Message reqMsg, Boolean bProxyCase)
       at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(Object NotUsed, MessageData& msgData)
       at System.Action`1.EndInvoke(IAsyncResult result)
       at umbraco.controls.ContentTypeControlNew.EndAsyncSaveOperation(IAsyncResult ar)
       at System.Web.UI.LegacyPageAsyncTask.CompleteTask(Boolean timedOut, Boolean syncTimeoutCaller)
    Request information:
        Request URL: http://..../umbraco/settings/editNodeTypeNew.aspx?id=9008
        Request path: /umbraco/settings/editNodeTypeNew.aspx
        User host address: 192.168.1.135
        User:
        Is authenticated: False
        Authentication Type:
        Thread account name: IIS APPPOOL\WPD
    Thread information:
        Thread ID: 53
        Is impersonating: False
        Stack trace:    at System.Web.UI.Page.ExecuteRegisteredAsyncTasks()
    Custom event details:
    Jul 23, 2013 @ 14:58
    Jeffrey Schoemaker
    Update of the problem: It turns out that it's just a time-out. The combination of 1073 images in the /umbraco/images/umbraco/ (Installed FamFam icons) and 54 properties gave a time-out.
    I fixed it by deleting some of the images /umbraco/images/umbraco/.
    @dawoe: Thanks for the help!
