  • Aron Gamble 63 posts 76 karma points
    Sep 30, 2009 @ 21:58
    Aron Gamble
    URL rewriting causes admin site to fail
    Implemented URL rewriting by configuring wildcards in IIS6 and adding a rule to UrlRewriting.config. This seems to be working ok, i can hit pages in my site accessing:-
    <mysite>/jobs etc.etc.
    Tried to access:-
    <mysite>/Umbraco and get a 404 Page Not Found.
    Then tried adding a new rule for /umbraco to redirect to /umbraco/umbraco.aspx but that just caused the page to partially load with images missing and not much else...
    Any suggestions would be greatly appreciated!
    Ron
  • Chris Dunn 75 posts 127 karma points
    Oct 01, 2009 @ 00:42
    Chris Dunn
    Can you post the rule you added to the UrlRewriting.config file?  It would help in debugging the problem.
    Also check to sure the web.config file still contains /umbraco in umbracoReservedPaths.
    -Chris
  • bob baty-barr 1180 posts 1294 karma points MVP
    Oct 01, 2009 @ 02:28
    bob baty-barr
    you might have to go direct to /umbraco/umbraco.aspx
    try that...
  • jonok 297 posts 658 karma points
    Oct 01, 2009 @ 17:48
    jonok
    Try adding "/umbraco" to the umbracoReservedUrls value in the web.config. That fixed it for me.
    Oct 03, 2009 @ 12:01
    Aron Gamble
    Adding /umbraco to the umbracoReservedUrls value in the web.config did the trick!
    Thanks a lot for the replies.
    Aron
