  • Ian Pettman 25 posts 53 karma points
    Aug 12, 2013 @ 19:56
    Ian Pettman
    Publishing umbraco as a subsite in IIS 7
    I am  unable to view pages correctly (images and scripts path  distorted).
    I checked in web.config  and umbracoconfig and set the key for
    umbracoConfigurationStatus as true
    ResolveUrlsFromTextString as True in UmbracoConfig
    Still no luck.
    Version I am using :4.11.8
    I tried viewing the site in umbraco/ and it is showing all my nodes correctly but my media files are appended with /media (example : /virtualdirectory/media/media/image.jpg.
    I tried republishing and restarting IIS .
    And also all the site nodes are accessible but no images/scripts getting loaded. The image paths are referring to root URL media folder, which I hoped will be solved by republishing and changing the config files.
