  • Shaun 248 posts 475 karma points
    Aug 18, 2013 @ 10:24
    Shaun
    Missing right click menu in installed packages tree.
    Hi.
    I had trouble installing imagegen today. Before correctly finding the problem (duff stuff in web.config) I removed the dll's and removed all reference to the package from the config file manually.
    Reinstalled and all was well, however, having just installed another package (uCommerce) I discovered that
    A. I had no new datatypes
    and
    B. I had no right click context menu on anything in the installed packages folder. All the other right click menus are fine.
    Can anyone tell me how I can fix this? Is it a case of tweaking the data itself in the db, or is there some caching thing going on?
    Many thanks.
    Shaun
