Having a few issues in getting the doc2form (or any mailer) working with a gmail account. My client uses Google Apps, hence the custom domain also requires SSL (as per gmail settings) .
i.e. the error message is:
"The SMTP server requires a secure connection or the client
was not authenticated. The server response was: 5.7.0 Must issue a
STARTTLS command first. l12sm184614fgb.20"
In the web.config there doesn't appear to be anyway to turn on ssl in mailsettings in order to enable the email to send via a Google Apps account.
Have a look at the configuration I've detailed in another post.
However, turning on the SSL absolutely needs to be done from the code. If that option is not available in doc2form then I guess you're out of luck (unless it's open source? not sure, haven't used it).
In the contact form I use this to switch on SSL:
SmtpClient client = new SmtpClient(); client.EnableSsl = true; client.Send(mail);
I'm not getting any errors when submitting anymore, but it's late so
i'll have to get my client to specify wether it works or not tomorrow,
but i think it does, since it connects fine with the stmp/socket
whatever :-)
Enabling SSL for Doc2form
Hi guys,
"The SMTP server requires a secure connection or the client was not authenticated. The server response was: 5.7.0 Must issue a STARTTLS command first. l12sm184614fgb.20"
Would apreciate any feedback/comments.
Thanks.
You can set this just as Sebastiaan says... in the doc2form.ascx.cs file, which will be located in the /app_code folder when you install doc2form v3.
cheers,
doug.
Thanks guys
will give it a try
Simon
I had the same issue just now.
in doc2form.ascx.cs after line 1183
i just did the following:
And in web.config the following:
I'm not getting any errors when submitting anymore, but it's late so i'll have to get my client to specify wether it works or not tomorrow, but i think it does, since it connects fine with the stmp/socket whatever :-)
A little update: It works.
