  • Nab 15 posts 35 karma points
    Aug 19, 2013 @ 19:34
    Nab
    Adding a generic handler in umbraco
    I have just created a Paypal IPN generic handler (.ashx) in a simple web forms based asp.net application. However when I try to visit the url, I get the error
    The resource cannot be found.
    I think I have to tell umbraco that is an ashx file. Anyone knows what to do? Thanks.
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    Aug 19, 2013 @ 22:45
    Richard Soeteman
    Can't you add the url to the umbracoReservedUrls setting of the web.config file? I think it's handled by Umbraco now
    Richard
    Aug 20, 2013 @ 02:20
    Nab
    Hey thats exactly what I had done :) Sorry I forgot to reply here.
    Thanks anyway for your help.
  • Michael 22 posts 61 karma points
    Mar 21, 2014 @ 09:24
    Michael
    Can you tell me how do you achieve it? I encounter the same problem.
    Mar 21, 2014 @ 09:30
    Hi Michael and welcome to our :)
    In the web.config in your Umbraco folder there is a setting called "umbracoReservedUrls" as Richard mentions above. In there you can add your own path to a url that should be reserved so Umbraco ignores it since it know knows that this is not a url from the CMS. It looks like this and is found in the
    Should make sense when you look it up in the web.config.
    Hope this helps.
    Mar 24, 2014 @ 02:59
    Michael
    Thanks very much, Jan.
    It's very nice of you. it does work. hah...
    I'm new to Umbraco. I don't know how to work it with .NET, can you give me some related materials or recommend some books to me?
    Thanks in advanced.
    Michael
