  • Inmedia 124 posts 176 karma points
    Oct 02, 2009 @ 12:12
    Inmedia
    Horizontal ruler (<hr />) won't work in Richtexteditor...!?
    I am trying to use the hr-tag in the richtext editor, and when I do it shows up in the editor itself, but when I save it just disappears again.
    Has anyone had the same problem? And how do I solve it?
    Oct 02, 2009 @ 12:15
    dandrayne
    Does HR appear in the ValidElements list at \config\tinyMceConfig.config ?  It may just need to be added
    hr[class|style]
    Dan
  • mfeola 117 posts 221 karma points
    Apr 08, 2010 @ 17:11
    mfeola
    its there in mine but it is also getting erased and just an empty P tag is left in its place.  when inserted it puts the HR tag in a P tag but if you put it in manually it works.  not very UI friendly
  • Johan Möller 83 posts 137 karma points
    May 25, 2010 @ 10:48
    Johan Möller
    I'm looking into this aswell now. Is there any solution to this?
    Jun 03, 2010 @ 20:41
    mfeola
    i found that this works
    #hr[class|style]
    but i am not sure what the pound sign means... so use at your own risk i guess?
  • Chris Dunn 210 posts 401 karma points
    Jun 03, 2010 @ 21:39
    Chris Dunn
    # = Enables padding of empty elements. This will pad with &nbsp; if they are empty. For example, "#p".
    Here's a full list of what the control characters mean in validelements:
    http://wiki.moxiecode.com/index.php/TinyMCE:Configuration/valid_elements
    -Chris
