Here's what I have in urlrewriting.config:
<add name="Test" virtualUrl="^~/Test/ProductDisplay.aspx?CatID=1003" destinationUrl="~/products/dslr.aspx" ignoreCase="true" redirect="Application" redirectMode="Permanent"/>When I enter the url, it is as if the config file isn't ever read. little help?
Hi Jesse, I am new to Umbraco too. I don't know whether it is the reason, but have you tried touching web.config to get the config reloaded?
have you tried including rewriteUrlParameter="IncludeQueryStringForRewrite" in your rewrite?
<add name="Test" virtualUrl="^~/Test/ProductDisplay.aspx?CatID=1003" destinationUrl="~/products/dslr.aspx" ignoreCase="true"redirect="Application"redirectMode="Permanent"rewriteUrlParameter="IncludeQueryStringForRewrite"/>
Thanks! I tried reloading the web.config which got me to square 1 so thank you! (rookie mistake...). Then I tested the following and it works great.
<add name="Test" virtualUrl="^~/Test/ProductDisplay.aspx" destinationUrl="~/products/dslr.aspx" ignoreCase="true"redirect="Application"redirectMode="Permanent"/>
My dilemma is the "?CatID=1003" after the ProductDisplay.aspx. I tried the rewriteUrlParameter that Claus suggested but no go. I think the "?" is being read as an expression rather than being taken literally. Any way to change this?
thanks!
Jesse
Okay...I have a new expression that goes into an infinite loop...
<add name="Test"virtualUrl="~/Test/test.aspx\?CatID=1003"destinationUrl="~/products/dslr.aspx" ignoreCase="true"redirect="Application"redirectMode="Permanent"/>It now gives the 301 but won't execute the destinationURL. Maybe a conflict with IIS6?
Upload image
urlrewriting.config not being read?
<add name="Test"
ignoreCase="true"
<add name="Test"
ignoreCase="true"
<add name="Test"
ignoreCase="true"
thanks!
Jesse
<add name="Test"
ignoreCase="true"
