I believe I followed the latter pretty closely but for the past couple of days all I am getting is the error “The type or namespace name 'ContactViewModel' could not be found (are you missing a using directive or an assembly reference?)” and I was wondering if someone could tell what I doing wrong?
My Platform: Windows 8, Umbraco6.1.4 set up on local IIS (not Express), Visual Studio 2012
My process:
1.Opened the website in VS 2012 and added folders Models and Controllers (not there initially)
2.Added new class ContactViewModel.cs to Models folder (see code below)
Note: When adding the new class to either I got prompted to add it to the App_Code instead but carried on regardless.
using System; using System.Collections.Generic; using System.ComponentModel.DataAnnotations; using System.Linq; using System.Web;
public class ContactViewModel { [Required] public string Name { get; set; } [Required] public string Email { get; set; } [Required] public string Enquiry { get; set; } }
3.Added new class ContactFormSurfaceController.cs to Controllers folder (source code below)
using System; using System.Collections.Generic; using System.Linq; using System.Web; using System.Web.Mvc;
public class ContactFormSurfaceController : Umbraco.Web.Mvc.SurfaceController { [HttpPost] public ActionResult sendEnquiry (ContactViewModel model) { //model not valid, return current umbraco page
if (!ModelState.IsValid) { return CurrentUmbracoPage(); }
Basic MVC Form: Missing model?
I am quite new to MVC and I trying to add a simple form my website based on the “partial view” example (i.e. http://our.umbraco.org/documentation/reference/mvc/forms/turorial-partial-views).
My process:
1. Opened the website in VS 2012 and added folders Models and Controllers (not there initially)
2. Added new class ContactViewModel.cs to Models folder (see code below)
using System;
using System.Linq;
using System.Web;
[Required]
[Required]
[Required]
3. Added new class ContactFormSurfaceController.cs to Controllers folder (source code below)
using System;
using System.Linq;
using System.Web;
[HttpPost]
//if validation passes perform whatever logic
//Do something...
//the redirect to 'thank you' page
return RedirectToUmbracoPage(1065);
4. Using Umbraco backend, I then added a new Partial View (ContactForm.cshtml) with the following code:
@model ContactViewModel
@using (Html.BeginUmbracoForm<ContactFormSurfaceController>("sendEnquiry"))
@Html.EditorFor(x => Model)
<input type="submit"/>
5. Lastly I created a new document type and template to display the partial view
Layout = "Root.cshtml";
@Html.Partial("ContactForm")
Any idea, what I am doing wrong?
