Has the FormatDateTime() method changed in Umbrac v6 ?
this used to work:
umbraco.library.FormatDateTime(article.GetPropertyValue("mediaArticlePublicationDate"), "dd/MM/yyyy")
now I'm getting this error message in VS
Error 226 The best overloaded method match for 'umbraco.library.FormatDateTime(string, string)' has some invalid arguments c:\Repos\cjs_cms\Views\MacroPartials\MediaArticleList.cshtml 36 21 C:\Repos\cjs_cms\
found out that this works:
@if (article.HasValue("mediaArticlePublicationDate"))
string date = article.GetPropertyValue("mediaArticlePublicationDate").ToString();
@umbraco.library.FormatDateTime(date, "dd/MM/yyyy");
Hi Anthony I would use something like this if you are using umbraco 6 with strongly typed.
@if(article.HasValue("mediaArticlePublicationDate") { @(article.GetPropertyValue<DateTime>("mediaArticlePublicationDate").ToString("dd/MM/yyyy")) }
Hi Ali,
Thanks for the tip. I tried this:
<dd><time datetime="@Model.Content.GetPropertyValue<DateTime>("mediaArticlePublicationDate").ToString("dd/MM/yyyy")"></time>...</dd>
though the compiler is complaining:
Error1Cannot convert method group 'GetPropertyValue' to non-delegate type 'object'. Did you intend to invoke the method?
this will sort it out:
when you use <> within the markup you need to wrap razor with ()
<dd> <time datetime="@(Model.Content.GetPropertyValue<DateTime>("mediaArticlePublicationDate").ToString("dd/MM/yyyy"))"></time> </dd>
oh I see. Thanks a lot, it's working now : )
Upload image
cannot format DateTime using umbraco.library.FormatDateTime()
this used to work:
Hi Ali,
