I'm getting this error on certain document types all of a sudden, any idea why?
Could not load type 'umbraco.DataLayer.SqlHelpers.umbraco.DataLayer.SqlHelpers.SqlServer.SqlServerHelper.umbraco.DataLayer.SqlHelpers.SqlServer.SqlServerHelperHelper' from assembly 'umbraco.DataLayer, Version=1.0.4933.21222, Culture=neutral, PublicKeyToken=null'.
Sudden error on certain document types
Hi Amir,
What version of Umbraco are you using, and do you have Contour installed on your Umbraco installation.
DonĀ“t know if this can help you, but seems to me that error message similar to to this one.
http://our.umbraco.org/forum/umbraco-pro/contour/44971-Error-when-installing-contour
I hope this post can help you in some way to solve your issue.
/Dennis
This ended up being an issue with a redirect, it was causing that error for some reason...
