the proof of concept package was a client project, and not really avaialbe for download...
in the basic rotator the implementation does not reallly allow for a link... just clicking to the next image.
i have moved away from such simple flash implementations for image rotators... for somethign simple like that, i recommend jquery [check out jquery cycle()] it will suit most of your needs and even more!
i did get your email too, but hopefully, this note will suffice.
simple flash rotator 1.0
Can you tell me how i can add link on each image on simple flash rotator1.0. located on:
http://packages.maliciousthinktank.com/rotatordemo/simple-rotator-macro.aspx
And how i can install Proof of Concept Proof of Concept pakage from:
http://packages.maliciousthinktank.com/rotatordemo/new-rotator-proof-of-concept.aspx
Regards,
Ok how i can install Various Flash Rotators pakage (Rotator Two) from:
http://packages.maliciousthinktank.com/rotatordemo.aspx
And if you want to buy the Proof of Concept rotator i can pay money for you .
Regards,
