  • Alan Mac Kenna 147 posts 405 karma points MVP c-trib
    Oct 17, 2013 @ 00:42
    Alan Mac Kenna
    4.7 install - Content node not showing any properties in backend
    I've a site running Umbraco 4.7.2. I haven't done anything to it recently but all of a sudden any node's of a particular doctype will not display correctly. When I navigate to the node all I'm seeing are the tabs and none of the properties.
    Here's how I've attempted to resolve:
    • Deleted the umbraco cache file
    • Republished the site
    • Saved the doctype again that is causing the issue.
    Needless to say none of the above has worked. Has anybody seen this before or have any suggestions how to fix? Screenshot attached.
    View of node
    Thanks guys,
    Alan
    Oct 18, 2013 @ 19:24
    Alan Mac Kenna
    any takers for this? I should also mention that any new nodes created from this doctype have the same problem.
    Cheers.
    Oct 18, 2013 @ 19:34
    Dennis Aaen
    Hi Alan,
    Your problem seems to be fixed by touching the web.config file. So try to make a change to the web.config file. and  then tried to refresh the site. You could also try rename the web.config, then refresh the site.after you have noticed the site will break, then change the name back to the web.config. Then I think your site should be up and running with propperties on the documenttypes.
    /Dennis
    Oct 18, 2013 @ 21:14
    Alan Mac Kenna
    Thanks Dennis,
    I tried as you suggested but no joy. It is only one of my doctypes that does this. Content nodes of other doctypes are fine. :/
    Alan
    Oct 18, 2013 @ 21:23
    Alan Mac Kenna
    I managed to fix this Dennis. It was one of the data type properties on the doctype had become corrupted (possibly through upgrades at some stage but only being noticed now.) The culprit was Media Picker with Preview. I just changed this to the standard Media Picker and that resolved my issue.
    Thanks for your help.
    Alan
    Oct 18, 2013 @ 21:25
    Dennis Aaen
    Hi Alan,
    Okay good to hearthat you was managed to solve the issue.
    /Dennis
