  • Jason 86 posts 156 karma points
    Oct 23, 2013 @ 20:48
    Jason
    Umbraco stripping out span id.....why?
    Hello,We're running Umbraco 4.52 built by a third party.  We recently took control of it and with that being said, we are extremely new to it and are trying to work out the bugs.The problem I am having today is that I am trying to drop some Hubspot code into the CMS (specifically into a ribbon body content area).The problem is that Umbraco strips out the "span id" which makes the code fail.  It keeps the class but strips the id.Is there a "trick" to get Umbraco to leave the code intact?What I drop in:<!--HubSpot Call-to-Action Code --><span class="hs-cta-wrapper" id="hs-cta-wrapper-d08e83de-357d-4e5b-bbfb-c768bf2ce180">    <span class="hs-cta-node hs-cta-d08e83de-357d-4e5b-bbfb-c768bf2ce180" id="hs-cta-d08e83de-357d-4e5b-bbfb-c768bf2ce180">        <!--[if lte IE 8]><div id="hs-cta-ie-element"></div><![endif]-->        <a href="http://cta-redirect.hubspot.com/cta/redirect/206683/d08e83de-357d-4e5b-bbfb-c768bf2ce180"><img class="hs-cta-img" id="hs-cta-img-d08e83de-357d-4e5b-bbfb-c768bf2ce180" style="border-width:0px;" src="https://no-cache.hubspot.com/cta/default/206683/d08e83de-357d-4e5b-bbfb-c768bf2ce180.png" /></a>    </span>    <script charset="utf-8" src="https://js.hubspot.com/cta/current.js"></script>        <script type="text/javascript">            hbspt.cta.load(206683, 'd08e83de-357d-4e5b-bbfb-c768bf2ce180');        </script></span><!-- end HubSpot Call-to-Action Code --> ...........and what remains:<!--HubSpot Call-to-Action Code --><span class="hs-cta-wrapper"><span class="hs-cta-node hs-cta-d08e83de-357d-4e5b-bbfb-c768bf2ce180"> <!--[if lte IE 8]><div id="hs-cta-ie-element"></div><![endif]--> <a href="http://cta-redirect.hubspot.com/cta/redirect/206683/d08e83de-357d-4e5b-bbfb-c768bf2ce180"> <img id="hs-cta-img-d08e83de-357d-4e5b-bbfb-c768bf2ce180" style="border-width: 0px;" class="hs-cta-img" src="https://no-cache.hubspot.com/cta/default/206683/d08e83de-357d-4e5b-bbfb-c768bf2ce180.png" alt="" /></a></span> <!--             hbspt.cta.load(206683, 'd08e83de-357d-4e5b-bbfb-c768bf2ce180');          // --></span> <!-- end HubSpot Call-to-Action Code -->Please let me know if I can provide any further information to help with a solution.Thank you in advance.
    Oct 25, 2013 @ 20:22
    Jason
    Anyone?  :-(
