cultiv contact form/sendmail not working on 4.11.10?
I posted this on the plugin section but it seems like it's almost dead. Hoping I might be able to get some help here.
I'm trying to get even the default cultiv razor contactform to send email from my 4.11.10 site. When I hit submit it appends #cultivcontactform to the url, but no emails go out. The redirectUrl parameter also will not work.
I've tried the default mail server settings and the gmail relay, neither seemed to make a difference. I have another site on the same host, everything else is equal except for the version of Umbraco.
I have a log entry:
"Error creating or sending contact mail, check if there is a mailFrom property on your document and that it has a value, or specify a MailFrom parameter on the macro call exception:"
All my settings are identical though (same mailserver). I get the same error when I try it through gmail.
Has anyone got this working under 4.11.10? I've tried everything I can think of and am too far in to rebuild the site.
I have a log entry:
thanks for any suggestions.
