Oembed v4.11.10 doesn't allow to assign id to iFrame.
Hi Guys,
Just upgraded a client of ours from version 4.7.1.1 to v 4.11.10 and they have an issue with how they insert embedded media specifically from YouTube. Previously they used the "insert embedded media" button and the could paste it the URL from YouTube, tab to "advanced" and give it an ID and all would work.
As of the upgrade, this "advanced" tab has disappeared and as far as I can make out so has the ability to add an ID to each embedded video. This then results in my TinyMCE stripping the video out on the save. I read this re oEmbed support from v 4.9 but again following this doesn't work unless I manually look at the HTML and add id element to the iFrame.
tinyMCE.config - all iframe elements are valid, tidy is turned on because this is a necessity.
Am I missing something here? Perhaps something is wrong in the new embedMedia.config but I haven't touched this from the original 4.11.10 install version.
Hi Guys,
Thanks in advance.
Liam
