  • Connie DeCinko 931 posts 1160 karma points
    Nov 19, 2013 @ 23:33
    Connie DeCinko
    Issues with custom membership provider
    I am using a custom provider for users of my Intranet to be able to login via Active Directory.  I am able to authenticate them and get the AD groups they are a member of.  When viewing the Members tab of the back office, I see the Member, I see the AD groups as roles and I see that the member is assigned to the Member Groups which match the AD groups.I go to my Content.  I assign public access on several content nodes.  For some odd reason, the user is only able to access the first restricted page.  All other pages are blocked.  It acts as if the member is only in the first Member Group, even though the Members tab says they are in several groups.Thoughts?
  • Fuji Kusaka 2203 posts 4220 karma points
    Nov 20, 2013 @ 07:00
    Fuji Kusaka
    In your content section have you set the proper Public Access under Role based protection ?
    Nov 20, 2013 @ 15:58
    Connie DeCinko
    I have.  The odd thing is, only when I select the first Role is the page accessible.  If I use any other Role, no one can access and is blocked.
