when i try to login into local umbraco cms 6.1.6.it is showing "404.17 error Not Found The requested content appears to be script and will not be served by the static file handler".
how to solve this problem.it is iis 7.5 version.
Try running C:\Windows\Microsoft.NET\Framework\v4.0.30319\aspnet_regiis -i
Be sure to run the command prompt "as administrator".
hi kipusoep,
it worked. thank you
404.17 error not found in umbraco 6.1.6?
Try running
C:\Windows\Microsoft.NET\Framework\v4.0.30319\aspnet_regiis -iBe sure to run the command prompt "as administrator".
hi kipusoep,
