You'd have to rewrite the .htm requests so that they map to the URLs that Umbraco is expecting (e.g. /page.htm to either /page or /page.aspx). You'd also have to create your own URL helper so that you could get all of the URLs with .htm on the end. If you forget to do that, you would end up with content available on multiple URLs, which causes duplicate content issues for SEO.
Best practice for URLs these days is to use extension-less URLs, like /page/ as that way you can change the underlying technology powering the site, without necessarily having to change the URLs. I'd strongly recommend doing that rather than using .htm extensions.
The Url Tracker is used to manage URLs within umbraco. It automatically tracks URL changes, for instance when a node is renamed, and makes sure the old URL will redirect to the new location. This is great for SEO and great for people visiting your website via this old URL.
Search engines will update the indexed URL and people won't visit the old, broken URL.
You can also create your own redirects, based on a simple URL or using a Regex pattern. You can redirect to an existing node or a manually entered URL. This is great for migrating existing indexed URLs to your new website!
Pages with html/htm extension
Just curious, is it possible to have pages with htm/html extension in Umbraco? and how?
to clarify this, instead of having a /abc/ which is actually /abc.aspx to be /abc.htm
Many Thanks.
So you just want to change the actual extension of your page from /abc/ to abc.htm ?
Or you want to add a Landing page or exclude page in your umbraco project?
You could, but it'd be a bit of work.
I agree that extension-less URLs are cool.
But I have an old site there all (or most...) URLs end with .htm.
I can name a content page e.g. program.htm or slash/slash/page. But when trying to access them in the browser, I get 404.
When converting an existing site to Umbraco, there should be a way to preserve old URLs like http://www.sjonleikarhusid.com/savn/2014/fo.html ? The coolest URL is one that never changes?
Hi Jan,
I think it would be a good idea for you to have a look at the 301 url tracker package https://our.umbraco.org/projects/developer-tools/301-url-tracker
Search engines will update the indexed URL and people won't visit the old, broken URL. You can also create your own redirects, based on a simple URL or using a Regex pattern. You can redirect to an existing node or a manually entered URL. This is great for migrating existing indexed URLs to your new website!
Hope this could be a solution for you,
/Dennis
It looks good. Better than I expected.
Jan Egil
