  • skiltz 501 posts 701 karma points
    Oct 14, 2009 @ 09:23
    skiltz
    TinyMCE + Front End
    Anyone have any ideas how to get the TinyMCE Datatype to render on the front end of the website?
    Oct 14, 2009 @ 18:29
    Hi Skiltz
    I don't think that it is possible in the way you may be thinking.
    The way I see it you have two option. Either use canvas to edit your pages on the frontend or you can use tinymce. If you choose to use tinymce you need to grab the javascript code from here http://tinymce.moxiecode.com/download/full.php (maybe you can even just make a reference for the files used in umbraco?) and then see the examples page on how you set it up http://tinymce.moxiecode.com/examples/full.php
    You simply just need a textarea on your page and then, as far as I recall from the top of my head, tinymce automatically makes an overlay, which enables you to format your text etc.
    If you are using AutoForm or Doc2Form you must be sure that you have set ValidateRequest = false; - For more information please read about it on Rasmus' blog http://lynggaard.nu/2009/02/validaterequest-in-umbraco-v4/ - It has something to do with security when you allow HTML to be submitted.
    Hope this helps.
  • Masood Afzal 176 posts 522 karma points
    Oct 14, 2009 @ 18:32
    Masood Afzal
    umbraco.editorControls.tinyMCE3.webcontrol.TinyMCEWebControl control = new umbraco.editorControls.tinyMCE3.webcontrol.TinyMCEWebControl();
    control.Text = "every thing is possible";
    Oct 14, 2009 @ 19:37
    Ok, so maybe it is possible after all. Thanks for showing Masood :)
    Oct 14, 2009 @ 20:11
    Masood Afzal
    Jan, i have never tested though. I think it will work if appropriate files have been included (as noted by yourself)
    thanks
    Masood
    Oct 16, 2009 @ 11:43
    skiltz
    This works but doesn't popupate the umraco tiny mce "theme"
    Oct 16, 2009 @ 12:04
  • Abtin Ghods 19 posts 61 karma points
    Jan 29, 2012 @ 13:39
    Abtin Ghods
    You can also try this
     DataTypeDefinition dtf = new DataTypeDefinition({the idea of the datatype, in case of default RichText Editor, -87});
     IDataType dt =  dtf.DataType;
     xPanel.Controls.Add((System.Web.UI.WebControls.WebControl)dt.DataEditor.Editor);
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Jan 29, 2012 @ 22:32
    Jeroen Breuer
    Here's a full example: http://our.umbraco.org/forum/developers/extending-umbraco/6863-Datatype-on-normal-page-or-UserControl?p=1#comment49125
    Don't think it works on the frontend. Still need some Umbraco controls, but it works in a custom section.
    Jeroen
