I've gotta create a site where alot of data will probably be repeated from time to time. Or atleast used as a base for a new document node. For instance this could be data for a textfield.
I want to set this up so that when creating a new document of a certain kind, i can either select one of these preset values or fill in a new text for my document. Ideally this new text should then be saved so it can be used in the future when creating a new document.
I got some ideas on how i can save these presets (either as own documents by setting up a specific document type and then use relations or by data type pre values. But im not sure how i can alter the create new document interface so that a user cannot both select and write their own texts as well as having the system save a new preset when a document is saved with a new text.
Any ideas or anyone who have done something similar?
Best way to go about preset document properties?
Hello.
Thanks in advance.
