  • Pete 213 posts 285 karma points
    Dec 11, 2013 @ 17:30
    Pete
    Help!! XmlException: There are multiple root elements
    I'm trying to re-publish a clients site to get it to rebuild the indexes in the temp folder as it is throwing a lot of razor macro script errors at the moment.
    However when I try to publish I get a:
    XmlException: There are multiple root elements error.
    I've tried deleting the umbraco.config file, then touching the web.config but it doesn't sold the problem. It rebuilds the config but I still get the error.
    How can I debug this? What can I check for?
    Update: it's the InternalIndexer that will not rebuild.
    The type initializer for 'Examine.ExamineManager' threw an exception.    at Examine.ExamineManager.get_Instance() - See more at: http://www.arendezvous.com.au/?umbDebugShowTrace=true#sthash.bvJvX7tD.dpuf
    Dec 12, 2013 @ 12:18
