  • Pete 213 posts 285 karma points
    Dec 19, 2013 @ 17:01
    Pete
    IIS Rewrite Module rules for Directory Urls
    I've moved a site onto a new host and as such directory urls no longer work, however the new host has the IIS rewrite module installed so I have added the following rulesto use it, but they don't seem to quite work.
    I'd like the links to be seo friendly e.g /mylink/ and not /mylink.aspx - and then to appear as /mylink/ in the address bar when navigated to.
    Here's my web.config section.
    <rewrite>
          <rules>
                    <!-- SEO: Using Directory URLs, so force trim all .aspx -->
                    <!-- exclude umbraco folder -->
                    <rule name="Trim aspx for directory URLs" stopProcessing="true">
                        <match url="(.*)\.aspx$" />
                        <conditions>
                            <add input="{REQUEST_URI}" pattern="^/umbraco/" negate="true" />
                        </conditions>
                        <action type="Redirect" redirectType="Permanent" url="{R:1}/" />
                    </rule>
                    <!-- SEO: Add trailing slash to URLs -->
                    <!-- better for SEO to *have* the trailing slash -->
                    <rule name="Add trailing slash" stopProcessing="true">
                        <match url="(.*[^/])$" ignoreCase="true" />
                        <conditions>
                            <add input="{REQUEST_FILENAME}" matchType="IsFile" negate="true" />
                            <add input="{REQUEST_FILENAME}" matchType="IsDirectory" negate="true" />
                            <add input="{URL}" pattern="^.*\.(asp|aspx|axd|asmx|css|js|jpg|jpeg|png|gif|mp3)$" negate="true" ignoreCase="true" />
                            <add input="{URL}" pattern="/Base" negate="true" />
                            <add input="{URL}" pattern="cdv=1" negate="true" />
                        </conditions>
                    </rule>
          </rules>
          </rewrite>
    With these rules I get /mylink.aspx/  , then if I turn on umbracoUseDirectoryUrls I get a 404 error on /mylink/
    Pete
