How can i change node url format ("localhost:56752/post/2014/january/09/test-for-node-url/") of ublogsy post to "localhost:56752/test-for-node-url/". Is it possible..?
I also would like an answer to this. I can't seem to disable the year / month / day sorting even though I've disabled it in the config. What other option do I have? I'd rather not have people seeing such long URLs.
Change URL format of ublogsy post node
Hello..
This is possible if you are using Umbraco 6.1 or higher. You need to use a UrlProvider and IContentFinder.
In the Hybrid Framework I have an example where I add a date to the news url. You need to do something similar:
https://github.com/jbreuer/Hybrid-Framework-for-Umbraco-v7-Best-Practises/blob/master/Umbraco.Extensions/UrlProvider/NewsUrlProvider.cs
https://github.com/jbreuer/Hybrid-Framework-for-Umbraco-v7-Best-Practises/blob/master/Umbraco.Extensions/ContentFinder/NewsContentFinder.cs
Jeroen
