  • Hardy Wang 91 posts 112 karma points
    Jan 09, 2014 @ 17:31
    Hardy Wang
    Umbraco 4, Exclude User from Using Some Certain Nodes
    I have set up some users to access all content nodes from root. Is it possible I can exclude them from accessiing certain nodes?
    Jan 09, 2014 @ 18:14
    Jeroen Breuer
    Yes this is possible. In the user section go to user permissions and select the user you want to change. There you can click on a node and disable the Browse Node option for that node and all it's childeren. Than that user can't see the node anymore.
    Jeroen
