  • hrdfsique 3 posts 23 karma points
    Jan 14, 2014 @ 20:23
    hrdfsique
    Examine Search Indexes and NiceUrl() return 404
    I am coming into this project new and have never experienced Umbraco until now.  The search function wasn't working and I found that the config "name" was incorrect...
    After the search started returning results, I noticed that all of the urls were returning a 404 error.  The url is being built by passing the SearchResult object's Id field into the NiceUrl() method.
    return umbraco.library.NiceUrl(sr.Id);
    From what I can see the url isn't building the full url...
    So... we are using:
    • Umbraco 6.0.4
    • WebForms
    An example would be a url like http://MyDomain/The-Search-Page-You-Are-Looking-For.aspx, when in fact it should be something like this:  http://MyDomain/News/Details/The-Search-Page-You-Are-Looking-For.aspx
    I have gone through hours of postings here as well as the documentation walk through and a couple other helpful blogs on the matter but can not find a solution or anyone else having the same problem.
    One factor I was told is that the website was originally set up with static pages and now is completely generated dynamically...  I checked to see if the index was being written correctly and it is... so now I'm stumped.
    Any Ideas or helpful points in the right direction?
    Jan 14, 2014 @ 22:03
    hrdfsique
    It seems that the NiceUrl is creating the url the exact way that is found in the Properties page of a content page that you configure at http://MyDomain/umbraco/umbraco.aspx#content.
    Link to document is /The-Search-Page-You-Are-Looking-For.aspx
    Alternative Links is  http://MyDomain/The-Search-Page-You-Are-Looking-For.aspx
    This page has two parent nodes...
    - about
    - news-details
    The actual page looks like this... http://MyDomain/about/news-details.aspx?newsID=1425
    The alternative link is the same as what the NiceUrl( id ) creates and doesn't work.  How do I get the two parent nodes as well?
