  • Kate 267 posts 610 karma points
    Jan 20, 2014 @ 12:23
    Kate
    Move af Umbraco 6.1.6 to another domain
    I have an Umbraco instaltion 6.1.6 running on SQL CE4 database.
    It's just a test site, but I would like to move it to a new domain.
    How do I do it?
    Thanks in advance
  • Fuji Kusaka 2203 posts 4220 karma points
    Jan 20, 2014 @ 12:43
    Fuji Kusaka
    Hi Kate,
    Are you using SQL CE4  on local machine ?
    Am doing the exact same thing atm, may be that could help you. http://our.umbraco.org/forum/core/general/39643-Migrating-from-SQL-CE-to-Express#
    Jan 20, 2014 @ 12:51
    Kate
    No, it's not on a local machine :-)
    I will have a look at your link
    Jan 20, 2014 @ 12:55
    Fuji Kusaka
    Ok but in anycase it should be the same thing.  I will let you know what i came up to. I tried changing this annoying localhost:43030 to something else but just cant get it working either so instead but making use of SQL Express with IIS.
    Jan 20, 2014 @ 13:09
    Dennis Aaen
    Hi Kate,
    If you just want to continue using a SQL CE database, then you should just upload all the files from your umbraco folder, to the new domain by using a FTP client, like FileZilla.
    After the upload is finished, you should be able to visit the new domain, and you site should be running.
    /Dennis
    Jan 20, 2014 @ 13:23
    Kate
    Hi Dennis
    That was what I hoped would happen, but I can not download the file: Umbraco.sdf folder App_Data.
    Therefore I can not upload the file to the new domain.
    It's a little strange, right?
    /Kate
    Jan 20, 2014 @ 13:32
    Fuji Kusaka
    @Denis. Am doing the same exact thing but do i have to go through all the installation process again  ? and i cant change the domain name in SQL CE with WebMatrix. Atm i have http://localhost:32441/ .
    Jan 20, 2014 @ 13:37
    Dennis Aaen
    Hi Kate,
    Okay I have experienced it before, is becourse the IIS locks files when it´s running. The way I solved it was by stopping the site and the app pool for the site in the IIS manager, Then you should be able to transfer your site to the new domain by FTP.
    Or yo could do a stop for the hole IIS, but it will of course have effect on other sites if you have more sites running on the same machine.
    Hope this helps,
    /Dennis
    Jan 20, 2014 @ 14:00
    Kate
    I have now idea how to do that :-(
    I use unoEuro as my webhotel, so I don't think I have any control over the IIS. I better have at talk with them :-)
    Jan 20, 2014 @ 14:14
    Dennis Aaen
    Hi Kate,
    I´m also use Unoeuro as my webhotel, and I follow this guide: http://www.unoeuro.com/support/faq/6/242/
    Hope this helps you, if not, then just write me and I'll see if I can help you through
    /Dennis
    Jan 20, 2014 @ 14:27
    Kate
    Hi Dennis
    That was the guide that unoeuro gave me too. But Im working on a Mac, so I could not use the IIS Manager. But unoEuro stop/started it for me :-)
    And now everything works.
    Thanks for your help... again ;-)
    /Kate
    Mar 24, 2014 @ 19:55
    Kate
    Hi all
    I had some problems after I uploaded all the files to the new domain. I got an error and some of the script files was not show correctly on the website.
    I asked Dennis what could be wrong. And he told me to delete the files in the folder  App_Data/TEMP and now it works :-)
    Mar 25, 2014 @ 07:58
    Dennis Aaen
    Hi Kate,
    I am glad that I could help you.
    /Dennis
