  • Ahmed 16 posts 96 karma points
    Jan 30, 2014 @ 09:48
    Ahmed
    sometimes umbraco doesn't save changes in document types and content
    sometimes umbraco fails to save the changes i make or document types i make after hours of working, it would be working fine as long as it is open then when i close it and open it again i find most of my work is gone but only document types and content documents and macros, the templates and xslts are not affected
    i am using umbraco v.6.1 with web matrix 7 on my local pc
    Jan 30, 2014 @ 10:17
    Ismail Mayat
    Ahmed,
    Probably silly question but are saving each time or thinking that umbraco has autosave? It does not have autosave you have to explicitly save also are you permissions correctly setup on your site?
    Regards
    Ismial
    Jan 30, 2014 @ 10:28
    Ahmed
    yes i save everytime
    it works fine before i close it, i create document types and content from those document types and publish them
    but they get deleted when i close it
    Jan 30, 2014 @ 10:30
    Ismail Mayat
    The content nodes in umbraco backend disappear or on the front end when viewing the site they dissappear? If they are on front end then its definately a permissions problem. If in the backend then something more serious is going on. Can you also check your log file which is found in app_data directory see if anything helpful there.
    Regards
    Ismail
    Jan 30, 2014 @ 10:42
    Ahmed
    the content nodes in the backend dissappear
    the log file doesn't show anything unusual just enteries about document types and content created and published
  • gchristakis 1 post 21 karma points
    Apr 01, 2014 @ 09:28
    gchristakis
    i have the exact same problem with umbraco. sometimes i lose the document types (not all of them but the last created ) sometimes exept the document types i lose the templates also. i 'm sure that i have save them and i'm working fine until i close the project and reopen it. i don't know what can i do cause i can't trust umbraco anymore .
    ahmed did you find a solution for this problem?
    thanks in advanced
  • Rui Nunes 1 post 21 karma points
    Aug 18, 2014 @ 16:41
    Rui Nunes
    Hi there!
    Has anyone found out why this is happening? I'm facing the exact same problem as described above. Thanks
