  • Magnus Engzell 3 posts 23 karma points
    Jan 30, 2014 @ 21:32
    Magnus Engzell
    Umbraco (6.1.6 on SQL CE Edition) crashed when installing '301 URL Tracker'
    I tried to install the '301 URL Tracker' in my Umbraco (6.1.6) running on a SQL CE Edition - and it crashed! The package had to be uninstalled manually.
    Anyone know if this package has problems on a SQL CE Edition or should I try again?
    Rgrds Magnus
  • Dan 1288 posts 3921 karma points c-trib
    Jan 30, 2014 @ 23:31
    Dan
    Hi Magnus,
    SQLCe isn't supported in the package at the moment unfortunately.
    Jan 30, 2014 @ 23:48
    Dennis Aaen
    Hi Magnus,
    If you see at the forum for this package there are some others that have some issues with installing the package on SQL CE,http://our.umbraco.org/projects/developer-tools/301-url-tracker/version-2
    I have tried it myself at tonight and I so get an error. But if you gets an error something like this:
    Error running NonQuery:
    SQL Statement:
    IF EXISTS (SELECT 1 FROM INFORMATION_SCHEMA.COLUMNS WHERE TABLE_NAME = 'icUrlTracker') AND NOT EXISTS (SELECT 1 FROM INFORMATION_SCHEMA.COLUMNS WHERE TABLE_NAME = 'icUrlTracker' AND COLUMN_NAME = 'ForceRedirect')
    BEGIN
       ALTER TABLE [icUrlTracker] ADD ForceRedirect bit NOT NULL CONSTRAINT DF_icUrlTracker_ForceRedirect DEFAULT 0
    END
    Exception:
    System.Data.SqlServerCe.SqlCeException (0x80004005): There was an error parsing the query. [ Token line number = 1,Token line offset = 1,Token in error = IF ]
      at System.Data.SqlServerCe.SqlCeCommand.ProcessResults(Int32 hr)
      at System.Data.SqlServerCe.SqlCeCommand.CompileQueryPlan()
      at System.Data.SqlServerCe.SqlCeCommand.ExecuteCommand(CommandBehavior behavior, String method, ResultSetOptions options)
      at System.Data.SqlServerCe.SqlCeCommand.ExecuteNonQuery()
      at SqlCE4Umbraco.SqlCeApplicationBlock.ExecuteNonQuery(String connectionString, CommandType commandType, String commandText, SqlCeParameter[] commandParameters)
    You could try to run these SQL scripts: https://github.com/kipusoep/UrlTracker/tree/master/SQL
    I get another error, but I just set up the test site, for try to helping you out so no worries about it.
    Or you could try to do what Dan says in this thread; http://our.umbraco.org/projects/developer-tools/301-url-tracker/version-2/47330-Error-when-installing-with-SQL-CE
    I hope this can help you to a solution.
    /Dennis
    Jan 31, 2014 @ 08:47
    Magnus Engzell
    Thanks for quick answers. I will take a look at it and see what I can do.
    // Magnus
