I am a complete beginner with Umbraco but I have installed Umbraco 6.1.6 using Webmatrix on my local system and so far I am finding it to be excellent.
One problem I have found is that when I am using IE 11, the view source window that appears when pressing the "html" button on the backend editor is empty,with none of the html being displayed, when using Chrome the source code displays correctly.
Is there something I might be doing wrong or is this a bug with IE 11?
Editor does not display HTML Source
Hi all
Tommy
Yeah, using IE as you main browser)
But seriously yes, it is an IE(11) issue, I second that)
Zakhar
Are you having this issue with Chrome, Ff or even Safari or previous version of IE ?
Not sure but have a look at this post.
Thanks for the replies.
Zakhar, thanks for confirming that this appears to be an IE issue.
Fuji, I dont have this problem with Chrome but havent tried on any earlier versions of IE.
Thanks for link to post will have a read later.
Tommy
