  • René Andersen 238 posts 684 karma points
    Feb 06, 2014 @ 15:05
    René Andersen
    Reset sdf file but keep tabs and document types
    Is it possible to reset a sdf file / database and still keep tabs and document types that I have made.
    //René
  • Jeroen Breuer 4908 posts 12265 karma points MVP 5x admin c-trib
    Feb 06, 2014 @ 18:01
    Jeroen Breuer
    I don't think that is possible. That data is stored in the database. If you want to keep it you need to store that data somewhere external. For example with uSync.
    Jeroen
  • Mike Chambers 636 posts 1253 karma points c-trib
    Feb 07, 2014 @ 10:12
    Mike Chambers
    you could also create a package containing your document types.. and then add that package to a clean umbraco install?
