I am receiving the following error when trying to edit one of my nodes from the content view. It only happens on one node. Do you know what this may mean?
Unable to cast object of type 'System.Web.UI.WebControls.Panel' to type 'umbraco.uicontrols.Pane'.
Exception Details: System.InvalidCastException: Unable to cast object of type 'System.Web.UI.WebControls.Panel' to type 'umbraco.uicontrols.Pane'.
Source Error:
Stack Trace:
[InvalidCastException: Unable to cast object of type 'System.Web.UI.WebControls.Panel' to type 'umbraco.uicontrols.Pane'.]
Our.Umbraco.DocTypeFieldsets.Events.CreateFieldsets.GetFieldset(Panel controls, String fieldset) +289
Our.Umbraco.DocTypeFieldsets.Events.CreateFieldsets.ContentControl_AfterContentControlLoad(ContentControl contentControl, ContentControlLoadEventArgs e) +1831
umbraco.controls.ContentControl.FireAfterContentControlLoad(ContentControlLoadEventArgs e) +22
umbraco.controls.ContentControl.OnLoad(EventArgs e) +38
System.Web.UI.Control.LoadRecursive() +54
System.Web.UI.Control.LoadRecursive() +145
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +772
No idea, but you might want to look into which properties are on the document type for this node and see if any of them may be causing this. I'm guessing all nodes of this type are throwing this error?
Umbraco UI error
Source Error:
