  • Sandro 45 posts 118 karma points c-trib
    Oct 22, 2009 @ 13:14
    Sandro
    TidyEditorContent has no effect
    TidyEditorContent has no effect for my umbraco installation. I set it to "False
    <!-- clean editor content with use of tidy -->
    <TidyEditorContent>False</TidyEditorContent>
    but it seems that TinyMCE still tidies the content :(
    Oct 23, 2009 @ 09:35
    Sandro
    How can I disable the TinyMCE tidy function?
  • Chris 1 post 21 karma points
    Nov 20, 2011 @ 08:03
    Chris
    This is still a problem. In 4.7.1 I cannot disable the tidy function (which should not exist IMO) using the two config files / app restart details discussed throughout these forums.
    Has anyone successfully disabled the tidy in 4.7.1?
  • Andy 10 posts 31 karma points
    Dec 01, 2011 @ 19:24
    Andy
    I also can't disable Tidy. I've tried restarting the app pool, clearing the browser cache, nothing works. Any ideas?
  • Rik Helsen 670 posts 873 karma points
    Dec 09, 2011 @ 11:01
    Rik Helsen
    Experiencing the same issue in 4.5.2, and with the 4.7.1 tinymce, can't disable tidy at all...
    my topic: http://our.umbraco.org/forum/using/ui-questions/26700-TinyMCE-keeps-removing-extra-breaks-and-empty-spans
    Dec 12, 2011 @ 10:51
    Rik Helsen
    in my case the issue wasn't caused by tinymce or tidy, but by a custom dll called tinymceoverride.dll
