You'll have to excuse my ignorance as I am very new to Umbraco (6.1.6) and a little wet behind the ears.
I am using Umbraco to host mutliple site and want as much site separation as possible. To that end, I can see that you can create folders in the scripts node but I do not see the same option for styles.
Can anyone give me some recommendation on how to do this?
umbracoCssDirectory - by adding this to appSettings you can specify a new/different folder for storing your css-files and still be able to edit them within Umbraco. Default folder is ~/css.
CSS Folders
Kind regards
Phillip
Google is your friend. Found the answer!
Well... this will allow me to change the default css directory, but will it allow me to add additional ones?
Example:
/css/site1/style.css
/css/site2/style.css
