  • John Hodgkinson 613 posts 355 karma points
    Feb 21, 2014 @ 16:09
    John Hodgkinson
    MVC DropDownList binding from Controller
    I'm sure I'm overlooking the obvious here... I'm having trouble binding DropDownList data from a controller to when rendering the form in the partial view... below is a condensed version... have tried numerous way to pass the list data back and bind to the dropdownlist but have not had any luck... many thanks in advance...
    ----CONTROLLER---
        public class MembershipDirectoryModel
            [Display(Name = "First Name")]
            public string FirstName { get; set; }
            [Display(Name = "Last Name")]
            public string LastName { get; set; }
            [Display(Name = "State")]
            public string State { get; set; }
        public class MembershipDirectorySurfaceController : Umbraco.Web.Mvc.SurfaceController
            [HttpGet]
            [ActionName("MembershipDirectory")]
            public ActionResult MembershipDirectoryGet()
                //populate the states options
                ViewBag.StatesList = GetStatesList("");
                ViewData["StatesList"] = GetStatesList("");
                TempData.Add("StatesList", GetStatesList(""));
                //return model to partival view
                return PartialView("MembershipDirectory", model);
            [HttpPost]
            public ActionResult MembershipDirectoryPost(MembershipDirectoryModel model)
                TempData["Status"] = "you submitted the form searching for: firstName = " + model.FirstName + " lastName = " + model.LastName + " state = " + model.State;
                return RedirectToCurrentUmbracoPage();
            public List<SelectListItem> GetStatesList(string selectedValue)
              //call to DB to get states options and returns list
    ---PARTIAL VIEW---
    @model ncba.applications.Membership.SurfaceControllers.MembershipDirectoryModel
    using (Html.BeginUmbracoForm("MembershipDirectory", "MembershipDirectorySurface", FormMethod.Post, new {@class = "generic-form elements-row"}))
      <ul class="elements-horizontal">
       <li class="row">
        <div class="form-element">
         <label for="FirstName">First Name</label>
               @Html.TextBoxFor(model => model.FirstName)
       </li>
       <li class="row">
         <label for="LastName">Last Name</label>
               @Html.TextBoxFor(model => model.LastName)
       </li>
       <li class="row">
         <label for="State">State</label>
         @Html.DropDownListFor(model => model.State, (IEnumerable<SelectListItem>)ViewData["StatesList"], "Select a State")
       </li>
      </ul>
