  • vladzebu 59 posts 346 karma points
    Oct 23, 2009 @ 10:41
    vladzebu
    Node by path
    How can i create a node in C# if i know the path of the node ?
    i want something like : Node node=new Node(Path);
    Best regards , Vlad .
    Oct 23, 2009 @ 11:03
    Hi Vlad
    You can find the answer to your question in the document API. Here is a wiki entry, which gives you what you need http://our.umbraco.org/wiki/reference/api-cheatsheet/creating-a-document
