Don't think it will work on v3. Since it uses certain files in the umbraco_client directory that aren't there in v3 (/umbraco_client/ui/jquery.js, ... )
For Umbraco v3 you can use http://homepage.ntlworld.com/maynard-smith/YetAnotherMediaPicker v0.3.1.zip. This version only works for v3. Im currently working on an improved version of YetAnotherMediaPicker which is compatible with Umbraco v4. I will be released soon.
Improved Mediapicker - compatibility
Hello, it looks great, can it be used with umbraco version 3?
Comment author was deleted
