  • Chris Mahoney 242 posts 454 karma points
    Mar 05, 2014 @ 23:27
    Chris Mahoney
    Public Access and Upload property
    I have a site that handles "document management"; I have a document type that has properties for various metadata, and also has an Upload property so that the user can attach the actual PDF that the metadata pertains to.
    I'm in the process of setting up Public Access so that documents can be limited to authorised users. This works for the most part; users without permission cannot open the Umbraco documents. However, if the users have the full URLs to the underlying PDFs then they can view them without logging in.
    Is there any way to protect the actual uploaded files? I've taken a quick look at Media Protect but it appears to only work for content in the Media section. Unfortunately this "protection" requirement has been dropped on me late in the development cycle so I'd prefer not to have to move everything over to Media if possible. So, is there any way to protect the underlying PDFs when they're in the Content section?
  • Richard Soeteman 4049 posts 12922 karma points MVP 2x
    Mar 06, 2014 @ 08:35
    Richard Soeteman
    Hi Chris,
    Media protect should help you with this requirement also. Did you already try it? Fully functional on localhost.
    Best,
    Richard
    Mar 09, 2014 @ 20:11
    Chris Mahoney
    I didn't try it; the documentation seemed to indicate that it only did the Media section (of course, I may have just misinterpreted it). I'll give it a go now and will let you know how I get on :)
    Edit: Well, that was quick and painless. Next time I'll actually try things before concluding that they don't work. Thanks! :)
