Need help creating a rewrite rule in UrlRewriting.config
I have searched infinity and beyond and have not been able to find the correct answer on how to successfully create a rewrite in our UrlRewriting.config file.
It seems like if you want the page to ALWAYS show up at online-mba-programs.aspx url you should rename the page as such and redirect from the old page to the new one like this.
What URL is the redirect resulting in that's giving you a 404 error?
Also, if you may want to look into this package, it takes the pain out of creating redirects and adds a nice dashboard control so you / your editors can monitor misdirected incoming traffic: http://our.umbraco.org/projects/developer-tools/301-url-tracker
Simply, we have the following page:
http://online.saintleo.edu/academics/masters-programs/mba.aspx
For SEO purposes, we want this page to always show up as:
http://online.saintleo.edu/academics/masters-programs/online-mba-programs.aspx
Can you please help me to create a successful rewrite within the UrlRewriting.config file?
Thank you in advance.
-Amir
Hi Amir,
Thank you for your assistance.
I tried what you recommended. It does rewrite, changing the URL, however, I get "Page Not Found".
This is what I place inside of the UrlRewriting file:
<add name="MBA"
virtualUrl="/academics/masters-programs/mba.aspx"
rewriteUrlParameter="ExcludeFromClientQueryString"
destinationUrl="/academics/masters-programs/online-mba-programs.aspx"
redirect="Domain"
redirectMode="Permanent"
ignoreCase="true" />
Thanks!
Hi Jason,
-Amir
Hi Amir,
When I had the rule in place, it was rewriting to the /academics/masters-programs/online-mba-programs.aspx but coming up as the 404.
We are actually having admin access granted (hopefully today) and then can look into the 301-url-tracker.
Jason
Hi Jason,
Out of curiosity, are you sure it wasn't resolving to this url? http://www.saintleo.edu/academics/masters-programs/online-mba-programs.aspx
I wonder if the hostnames are set up incorrectly or something. There's no reason that a redirect should end up with 404 on an existing page.
-Amir
Hi Amir,
Ok, so we had this custom built SEM (SEO) module built by a 3rd party which ended up failing after we parted ways.
I had unchecked the rule within this module the first time around.
I left the box checked this time and placed the rule that you provided into the UrlRewriting.config file and it's now working the way we need it to.
May be a bit confusing, but as long as it works now! Thank you so very much, Amir!
Going to go test it on a few other non working rewrites.
Best,
Jason
