  • Björn 10 posts 90 karma points
    Mar 12, 2014 @ 09:33
    Björn
    TinyMCE's advimage not working on published site
    Hey guys!
    I got a strange problem where TinyMCE's advimage isn't working on my published site but works when I run the site on my local machine (localhost...). I'm using TinyMCE 3 and Umbraco 6.1.5.
    I've added
    <plugin loadOnFrontend="true">advimage</plugin>
    to the tinyMceConfig file, is there something else I should do to make it work?
    Thanks!
    Mar 22, 2014 @ 19:12
    Hi Björn
    Did you managed to solve this?
    Otherwise are you certain that your live-site isn't lacking any files? If you use the inspector tool of your browser do you then see some error message in the console? Have you tried having a look in the /app_data/logs file to see if that reveals anything?
    When you deploy from your local site to your live-site what is your process? Have you perhaps forgot to copy over some files? Perhaps you forgot to copy over the config file? Otherwise you might missed recycling the app pool after the change?
    Hope these input helps!
    Apr 15, 2014 @ 09:49
    Björn
    Hi Jan! Never got a notification so I didn't see you reply until now, sorry!
    Still haven't managed to solve the problem and I don't think there are any files missing. I've also discovered that if you right click an image you get a menu option called "advanced.image_sec" which opens the advanced image editor! But when you click the "insert image button" above the editor you still get the regular image editor.
    Very strange...
    /Björn
    Apr 15, 2014 @ 10:13
    Hi Björn
    That happens sometimes unfortunately. And you're sure it did not end up in the spam folder?
    Hmmm - Are you logged in as a english/american user? Or do you log in using another language?
    Apr 15, 2014 @ 10:51
    Björn
    It turned out that I hadn't configured the notifications settings correctly so it was my fault :)
    I'm logged in as administrator and the language is set to English (UK).
    /Björn
    Apr 15, 2014 @ 12:51
    Hi Björn
    Glad you got it solved :)
    Apr 15, 2014 @ 13:09
    Björn
    Hehe, I was talking about the notification here on umbraco.org :)
    I still have the TinyMCE problem...
    /Björn
    Apr 15, 2014 @ 13:52
    D'oh! Of course - sorry 'bout that :)
    Do you see any errors in the console log of your browser when you browse a node where you would expect a rich text editor?
    Apr 15, 2014 @ 13:57
    Björn
    No worries :)
    Nope, no errors in the console log.
    /Björn
    Apr 15, 2014 @ 14:58
    Ok, could you try doing an upgrade like I suggested earlier?
